Red light in mirror
Leknes, Norway
I've seen on the web that someone has red ST light from the mirrors down on the ground, is this one included with the car? or possibly where to fix it? Since I have talked to the sellers in Norway and they can not answer it until the next year when the car comes to Norway
Jules
Absolutely I have that when the truck is lit up while in park. I thought it was standard option.
Cincinnati, OH
The ST projection LED lights are included as a standard option.
Explorer-Lofoten
Leknes, Norway
Thank you:):)
kartman
AZ
Anyone know how to disable it?
tontda
Hawaii
There should be a button to disable it located in the overhead console controls.
slope
maryland
Disable it??
That's the one thing on mine that still works!
Blrmmr
Anyone thought or know how to change the color?
KegsBdry
WashDC
Try GREEN tint over the light. Red & Green make Yellow Screenshot_20201130-070423.jpg .
B.Beauty
Newport, RI, USA
Don't know if it is the lens or the bulb. Should be an easy fix if it is a bulb. More complicated if it is the lens.
Buffalo, NY, USA
Reviving this old thread... anyone know the best spot to tap into the power wire for these ST flood lamps?
Washington D.C., DC, USA
More revival...has anyone taken apart the mirror or know more about the ST projection? I would love to figure out a way to change it from ST to something else, I assume it is probably just a stencil the light projects through?
Buffalo, NY, USA
I found the wiring harness for what its worth! Will look at trying to get a blow out of the mirror assembly
Excalibur
Moncks Corner, SC
Has anyone figured out a method to change the color yet?
