Recirculate BOV vs. Vent to Atmosphere BOV
Albuquerque, NM, USA
If i was going to buy again i would buy the VTA version. sounds better but at the same time it is not too loud. not like how crazy my focus with the HKS SSQbov. take a listen for yourself.
I hope this video helps you decide what you want to buy.
Why would you want to hear this Moby Dick sounding BOV spurting off every few seconds. Sounds like your applying the brakes on a big rig. I can see an emergency blow off valve on a high pressure boiler but not a 6 cylinder SUV. Guess my sugar high just kicked in o_O !!
Woodstock, GA, USA
Which model and brand is the VTA?
CA
I just stuck the Whoosh VTA adapter on mine. I personally love the sound when you're driving enthusiastically and let off on the throttle.
As the factory bypass valve is electronic, it doesn't activate on low boost, mild/moderate throttle. So when driving 'normally', it usually doesn't trigger.
Not like a vacuum actuated valve that opens every time you let off and pull a vacuum.
Sent from my SM-G991W using Tapatalk
FatGuyBuilds_YT
my stock one was leaking. the aftermarket versions seal better. if you look at how the sealing mating service looks.
Stinger
Active Duty U.S. Navy
Madison, WI, USA
I would like to hear it as the vehicle drives by to get an accurate assessment of what it sounds like when driving it on the street and there are pedestrians and other vehicles nearby.
I'm thinking about the dual port TS BOV.
