FACTORY MODE DISABLE AND MANUAL PARK RELEASE COVER INSPECTION
NHTSA Recall Number: 19V575 NHTSA Date:AUG 05, 2019 Ford Recall number: 19C06
Recall Description:FACTORY MODE DISABLE AND MANUAL PARK RELEASE COVER INSPECTION
Risk to Safety:VEHICLES WITH THE MPR COVER NOT INSTALLED MAY HAVE THE MPR LEVER INADVERTENTLY ENGAGE, WHICH COULD RESULT IN UNINTENDED VEHICLE MOVEMENT OR ROLL AWAY, IF THE ELECTRONIC PARK BRAKE IS NOT APPLIED, INCREASING THE RISK OF INJURY OR CRASH. IF VEHICLE IS IN FACTORY MODE YOU MAY HAVE WARNING ALERTS AND CHIMES THAT ARE NOT FULLY FUNCTIONING. IF THE DRIVER IS NOT ALERTED TO CERTAIN WARNINGS, IT MAY ALSO INCREASE THE RISK OF A CRASH
Remedy Program: FORD MOTOR COMPANY HAS AUTHORIZED YOUR DEALER TO INSPECT THE MPR LEVER POSITION AND INSTALL THE COVER IF MISSING AND VERIFY AND VERIFY THAT THE INSTRUMENT CLUSTER IS OUT OF FACTORY MODE FREE OF CHARGE (PARTS AND LABOR).
Manufacturer Notes:TO CHECK FOR NON-SAFETY-RELATED PROGRAMS APPLICABLE TO YOUR VEHICLE, SEE HTTP://WWW.FORD.COM/ OR CALL YOUR FORD DEALER.
