rear suspension airbags
Orlando, FL, USA
Have a 21 ST. Will be towing a 3,500lb boat with a single axle trailer. I have put airbags on quite a few of my trucks for leveling purposes while towing. Haven't seen much for "exact fit" and was wondering if anyone has installed the universal fit and had any luck? On a side note....put the Borla Atak system on and it sounds great! Thanks for any input
I Bleed Ford Blue
23 Rapid Red Explorer ST
There is a company called Airlift that makes small airbags that go inside the coilspring specifically for the purpose you need. Take some measurements of the inside diameter of your rear springs and check their website and see if they make a universal one that could work. Turns they make one that fits the 20+ explorers.
https://www.airliftcompany.com/shop/60855/
