Rear differential leaking
South Carolina
Can you do the work yourself? Grab a 2 bolt diff cover, get the car up on stands then support the diff with a floor jack, pull all the bolts and lower the diff while rotating the rear downward, R&R the cover then put it all back together. Probably take you less than 2 hours.
Do you have to disconnect the axels to get the cover off?
STrip
California
I do not believe that you do, but there is not much room. Trying removing two rear bolts and then the two front bolts with the diff supported, then lower it down a little with the jack. Might be able to get the cover off that way.
