Rain guard consensus?
Shepherdsville, Ky
Is there a general consensus of which rain guards are best fit for 2025 st?
Do avs fit without any closing issues? Had weather guard on my 2017 limited
Illinois
I bought the low profile guards direct from Ford for my 25. They fit great and follow the window line perfectly. They are held on by double stick tape and attach to the window trim directly. I have had them on for about 14 months. They have been through multiple car washes and a Chicago winter without issues.
Caster
I have AVS on mine with no issue. I quit going with the in-channel design a while ago because of the window interference issue when it gets hot and they slightly warp.
Combatvet
I live in Texas and I've never heard of this warp issue, or interference with Weathertech in-channel design.The window trim eventually settles, and the windows operate as intended. It's all in the instructions.
Caster
I've had more than 1-pair of AVS in-channel design's where they will bow in high heat and interfere with the window going up. Never had it happen unless it was pretty hot. Never when cool or cold. Its a known issue with in channel guards.
Combatvet
Maybe with AVS, but not with Weathertech.This is my fourth vehicle with that brand.
B
Shepherdsville, Ky
Definitely want in channel
Sounds weathertec
joelk9
Indiana
I went with the in channel weather tech. Had to cut I believe the front edge of each rear door piece. If I didn’t trim them, they bulged out and the windows wouldn’t fully close.
Combatvet
Weird, I didn't have to modify at all.
joelk9
Indiana
I bought those because all the reviews said they fit perfectly. I tried on both sides incase I misunderstood the directions and still had to cut about 1/4”-3/8” off. Afterwards I realized I should have taken pictures incase I ever needed them for the forum.
Caster
I've had to modify (grind to fit) some of the AVS brand ones over the years..
B
Shepherdsville, Ky
Bought weather tec and will have to trim sides to keep rubber around window flat
Had the AVS, then the Weathertech. In the end, too much wind noise and not thrilled with how they look... removed.
