Question for the Forscan Wizards
Akuma
Virginia
I have a 2023 ST base version. I have followed the table and done all the things through forscan I can.
I have one issue that no matter how many times I reset everything the cornering fog lights will not work correctly.
When I turn right both fog lights turn on. When I turn left, neither turn on. I am fairly certain I had this working before I did a reset and reloaded my as built and then redid everything and now no matter if I put them on DRL, Corner, fog, or just fog and corner. No change. The only change that applies effectively is turning the fog control from fog and corner to just fog and that turns the corning off. Any help from the wizards id appreciate it.
