Power/Transmission Loss cruising at 50...
Southern California
2020 ST. 70K miles.
This is very similar to the hard acceleration/sudden lane change issue I have had and can recreate but the cause was different.
I was driving a steady ~50mph on a slight uphill grade multi lane highway. (PCH). I heard a "rustling" noise from under the car and then the transmission went to neutral and revving the engine only sorta worked. I luckily coasted to the side and restarted the car and all was well. I checked ForscanLite and there were NO error messages.
My GUESS is that I ran over something weird and it freaked out the computer. However, the rustling noise almost seemed too "slow" to be something being run over at 50mph.
Ugh. I miss old cars that would just keep running until something would tear up the old fashioned way
Thanks for any thoughts!
Dennis.
Sent from my SM-S938U1 using Tapatalk
Hopefully just a one time occurrence. If it happens again or throws a code, I’d be worried, otherwise I wouldn’t worry about it too much. What is this “sudden lane change issue”?
D
Southern California
Check your transmission fluid, these cars are notoriously under filled from the factory. Also, I know you’re problem, combined with low tranny fluid, when you’re at highway speed the car is in 9th or 10th gear, when you go WOT, it has to drop like 4 or 5 gears, so it hesitates and loses power a bit. Sport mode and correct tranny fluid level fixed this for me.
D
Southern California
Finally figured this out. Got the following error and dealer had to replace a broken parking pawl rod. Guess the broken piece was randomly bouncing around the transmission.
Crazy it took months to finally trip a sensor.
I guess this is why they did the software update last year (?) that automatically sets the parking brake to avoid bouncing against the pawl.
Hopefully this is it for awhile!
Mystic
Ottawa
My 2023 is currently with the same issue + random faults of solenoid stuck/unresponsive or that shifting did not occurred in a timely manner. Did 2 runs to dealer where they just did clutches software adjustments and shift tables resets. Have an appointment for next Tuesday with hopes that they will actually start putting car in the air and taking tranny out for inspection
