PIU Brakes Greasing Caliper Bracket Guide Pins
Southern New Jersey
I bought a set of used PIU Interceptor Calipers and Brackets to upgrade my Standard Brakes on my ST. I took them apart and had them painted. I noticed that the guide pins seem to have resistance sliding in and out. They move freely but a bit of resistance. I am not sure if that is the way they are supposed to be.. No signs of rust or damage on the pins and I have used the correct grease. I made sure to cover the slide pins holes when painted. Just want to make sure I am not installing Damaged brakes.
One of the pins has a rubber insert. I would pull the pins out and grease.
Massachusetts
2023 ST
Slide pins seizing up is a common issue with all calipers of this design in general.
Usually what i do is remove the slide pins, remove any rubber inserts on them and hit them on a buffer to shine the pins up. Then for the bores, i'll usually buy a hone brush for a drill. Add some lubricant and hone the inside of the bracket for a bit. Flush it all out with brake clean, relube with good synthetic grease and assemble.
Given where i live in the northeast, stuck/sticking slide pins tend to be common and I almost need to do this somewhat annually on many of the cars i've owned.
Farmers Branch, TX
Between the rubber boots and the tackiness of the grease, there should be some slight resistance. As long at the movement is smooth and doesn't bind anywhere it will be fine.
