P3Cars Gauge interests?
Nbk4t5e
San Antonio, TX, USA
Looking to see if anymore would be interested in this mod. I had it on my S7 and it is a clean look offering features like boost, air/fuel, 0-60 runs etc.
I spoke with them and they don’t plan on doing it for the ST unless I can get a solid number of people.
Check out the site and let me know what you think. Plugs into the OBDII
http://www.p3cars.com
Here are pix from my S7. Clean setup.
I was just looking at their stuff the other day. I’d be interested to see what they can come up with.
Nbk4t5e
Nbk4t5e
There is a universal one but you have to do the cutting. It’s a cool mod.
Let me see what kind of responses I can get. Probably needs to be a decent number.
LokiWolf
Henrico, VA
I would be interested.
Had their stuff in my Jetta and Passat. I was their tester for the Diesel coded versions on the Passat. They are top notch in quality!
Nbk4t5e
Nbk4t5e
I doubt we can get enough bites from others for them to make one, I’ll probably do the DIY one and cut it.
LokiWolf
Henrico, VA
Did you send them a message?
Nbk4t5e
Nbk4t5e
I spoke with them before I posted this and needed a decent following for them make an actual product for the ST. You are welcome to help if you know someone. I used the air fuel/ boost/ and 0-60 the most. I may do something custom with it. Just need to make a template for the vent. I was told they hand cut each one anyways.
LokiWolf
Henrico, VA
I will reach out. The rest of you should also!
Nbk4t5e
Nbk4t5e
Great thanks
