New high score for an ST dyno session!
Marinette, WI, USA
With the addition of Nostrum stage 3 injectors we were able to push Bart's (Kevin's former ST) to a new high score on the dyno!
774 AWHP and 678.4 Ft-lbs on E50
558 AWHP and 524 Ft-lbs on 93
mods
Xona Rotor 5451S upgraded turbos
Nostrum Performance high-pressure fuel pump
Nostrum Performance upgraded injectors (stage 3)
FENFAB upgraded intercooler
FENFAB high flow air intake
FENFAB upgraded charge pipes
Turbosmart blowoff valve
Turbosmart external wastegate
PTP Turbo Blankets turbo & wastegate blankets
FENFAB 3" downpipes
FENFAB/Vibrant Performance custom exhaust
FENFAB oil catch can
Accusump oil accumulator kit
FENFAB coolant tank
NGK spark plugs
Rotora big brake kit
Level10 Transmission built transmission
Meziere Enterprises billet flex plate
PPE Power 10R80 deep trans pan
TS Performance transmission launch controller
CircleD Specialties torque converter
FENFAB rear diff brace
FENFAB trans mount
FENFAB toe arms
Air Lift Performance custom air suspension
FENFAB front strut bar
Steeda rear sway bar
Velgen wheels 20x10 et34 classic5 V2
Wow, impressive!
ZFGracing
Marinette, WI, USA
Daaamn. That is a stock longblock too, rt?
correct that is the stock long block that has also been in the car since it originally made 701 awhp 1.5 years ago.
Suprawill1
Maryland
Must be interesting putting that power to the ground. :)
Gotta be running 10's - high 9's? Goodbye Track Hawk!
Chicago
Ford Explorer ST
Beyond excited. We'll be adding the Steeda diff brace, fenfab subframe bushings, fenfab rear vertical links, and forged internals in soon as well. Thank you so much.
CONNECTICUT
2020 EXPLORER ST
SICK!!!!!!!!!!!
CONNECTICUT
2020 EXPLORER ST
mods
FENFAB 3" downpipes
FENFAB coolant tank
NGK spark plugs
FENFAB trans mount
FENFAB toe arms
Wow that’s crazy to see the difference in 93 octane vs e50 - MASSIVE GAINS!
CONNECTICUT
2020 EXPLORER ST
Wow that’s crazy to see the difference in 93 octane vs e50 - MASSIVE GAINS![/QUOTE
how much
hypothetically- if you swapped out the turbos for crp stage 5 are you getting near the 700wheel mark?
