Lethal Spring
R
Roseville
Thread Starter #61
There really is a variance in spring height. I'm waiting for some replacement rear springs now from Lethal.
That will be interesting to see what difference you get.
Punta Gorda, FL, USA
#62
Just went out in garage and fronts are hanging at 17” I did drive the car about 25 miles and filled the gas tank and I’m at 17 3/4 on rear. I think I’m happy with it. Someday somebody might sit in the back seat. Lol. Plus if I really want to get in something lower our C8 fits the bill. 0DB38F1D-9248-43D6-B944-11F187D471CE.jpeg
I measured the heights again today and I'm at 17" in the front and 17 3/4" in the rear. So they do look like there are settling some. I just had another alignment done this morning.
thenewguy
Ottawa, ON, Canada
#64
but how different are these vs the H&Rs? Maybe someone with those can give similar measurements?
Mine with H&R’s is 17” f/r but the rear of mine doesn’t really count with the extra audio weight. That won’t effect the front though and these Lethal springs were advertised as a lower option than H&R…which they pretty clearly aren’t.
thenewguy
Ottawa, ON, Canada
#66
This is exactly what I've been asking them, put one side by side and lets see visually how different they are, if measurements are coming out to be the same, the hecks the difference lol
#67
Mine with H&R’s is 17” f/r but the rear of mine doesn’t really count with the extra audio weight. That won’t affect the front though and these Lethal springs were advertised as a lower option than H&R…which they pretty clearly aren’t.
No rear coil binding with a bit smoother ride.
R
Roseville
Thread Starter #68
I cant remember where but there is a comparison and Lethals looked lower. Might even be on their website. (sorry bad memory)
If you read thru the posts it seems none of the springs are consistent. It could be measuring errors the different years or just the way it is? But seems 17" in front is the lowest posted so far (HR and Lethal springs both) Lethal 17.5 in back seems to be the lowest from whats posted. there was even a poster with steedas that were as low as Lethals.
H&R 's - 17 3/8 " front and 17 3/4" rear.
Steeda: 17 3/8" front, 18 3/8" rear, installed just over a month.
#71
Can those listing measurements also include how long you've had the springs on your car? i have a feeling settling continues past the first few weeks, although less.
I have the very first run of H&R’s…possibly one of the first sets installed. I’m the one that had to figure out the rear alignment. lol
#73
2-3 coils touching is nothing abnormal with many progressive springs, especially H&R. They maybe inactive at resting position but when the wheels drops down on the road, they will soften the return to compression. I've had the same on H&Rs with two previous setups.
EdMan63
Farmington Hills MI
Installed Steeda springs on 2/9/23. Measured today and front is 17 3/4 and rear is 18 3/8's. So pretty consistent with many measurements seen here and pretty much what they advertise. I measured a stock unit here at work and front is 19 1/4 and rear is 19 1/2.
