Lethal Performance Stainless Steel Mid Pipes back IN STOCK!!
Wellington, FL, USA
Hey, ALL!
Back in stock are our Lethal Performance Mid Pipes for your Explorer ST!
The Lethal Performance 2.5" Stainless Steel Mid Pipes for the 2020+ Ford Explorer ST 3.0L are a direct replacement for your factory mid-pipes which require no cutting or welding for installation. These will replace the factory piping in between the downpipes and cat-back.
These pipes are compatible with all downpipes and cat-backs that use the factory style connection. Made right here in the USA with high quality T304 stainless steel, mandrel bent and welded to perfection.
Mid Pipe Features:
2.5" T304 Stainless Steel Tubing
Flex Pipes Included
Direct Replacement for Factory Mid Pipes
Factory Style Connection to Downpipes and Cat-back
Made in the USA
Check them out here --> Lethal Performance PLLP00005M 2.5" Stainless Steel Mid Pipes (2020-2022 Ford Explorer ST 3.0L)
As always, if you guys have any questions or wanna get a set on order; feel free to reach out to us here at Lethal Performance and we'll be more than happy to get you taken care of!
