Lethal Performance ST Mid-Pipes & Spacers ON SALE NOW!!
Wellington, FL, USA
Good Morning, #teamlethal fans!
New week means new sales!
We wanted to make sure and highlight just a couple of our most popular sellers... Our Lethal Performance full direct replacement Mid-Pipes & our Wheel Spacers!
The Lethal Performance 2.5" Stainless Steel Mid Pipes for the 2020+ Ford Explorer ST 3.0L are a direct replacement for your factory midpipes which require no cutting or welding for installation. These will replace the factory piping in between the downpipes and catback. These pipes are compatible with all downpipes and catbacks that use the factory style connection. Made right here in the USA with high quality T304 stainless steel, mandrel bent and welded to perfection.
Mid Pipe Features:
2.5" T304 Stainless Steel Tubing
Flex Pipes Included
Direct Replacement for Factory Mid Pipes
Factory Style Connection to Downpipes and Catback
Made in the USA
Ready to grab a set? Check them out here ---> Lethal Performance PLLP00005M 2.5" Stainless Steel Mid Pipes (2020-2025 Ford Explorer ST 3.0L)
Upgrade the looks of your 2020 and newer Ford Explorer ST with Lethal Performance Wheel Spacers! Engineered to bolt directly onto the stock hub for a seamless installation. These high-performance spacers feature a 114.3 x 5 wheel pattern and M14 x 1.5mm thread size, perfectly complementing the Explorer ST's specifications. With a hub-centric diameter of 70.5mm, they ensure precise alignment and enhanced stability, transforming your driving experience while providing a more aggressive stance.
Suggested Front Options:
- 1"
- 1.25"
Suggested Rear Options:
- 1.25"
- 1.5"
Features:
Forged Aluminum T6 6061
Hubcentric, bolt-on design*
12.9 grade hardware
Black hard coat anodized
114.3x5 wheel pattern
M14x1.5 thread size
*NOTE:
The 1" Spacers will require trimming of the OEM Wheel Studs for additional clearance.
for ST Line models, Stud Trimming will be required for all sizes
Ready to grab a set? Check them out here ---> Lethal Performance Wheel Spacers (2020-2025 Explorer ST)
JakeLethal
Wellington, FL, USA
Mid Pipe Features:
Flex Pipes Included
Made in the USA
- 1"
- 1.25"
- 1.25"
- 1.5"
Features:
12.9 grade hardware
M14x1.5 thread size
*NOTE:
It's your LAST CHANCE!
Today is the LAST DAY to get these amazing deals!
