Leaking Transmission Fluid
Surprise, AZ, USA
Hello...
Anyone else have an issue with leaking transmission fluid? Changed my oil the other day and noticed fresh reddish colored fluid on the undercarriage around what I assume to be the transmission pan. It appears (and I am assuming) to be transmission fluid. Don't think it could be anything else based on the location of the fluid. I have an appointment with the dealership on Monday. Just curious if anyone else has had any similar issues.
Thanks!
plenty have had trans oil leak related to the trans cooler.
R
Surprise, AZ, USA
Thank you for the response.
R
Surprise, AZ, USA
Just a quick update... It was the transmission cooler. Took two days to get part and dealership repaired vehicle the same day part arrived.
