Is turbo delay on departure after replacing only large intercoolers?
대한민국
2023 링컨 에비에이터
Polizi212
Changing the intercooler should not cause any turbo Lag. I could be wrong but I think that's what your asking!
Dominican Republic
Ford Explorer ST 2021
Yes, a larger intercooler can potentially contribute to more turbo lag
This but questionable if the butt Dyno could tell. Larger volume of space to pressurize before the pressure hits the throttle body.
New Mexico
You shouldn't see a difference on stock turbos before/after an intercooler install.
This is data from my car early in testing back in 2023, the boost plot is identical.
No. Won’t make any noticeable difference.
Charlotte
2024 Explorer ST
I didn't notice anything different. Never really felt lag in this vehicle before or after the IC upgrade. Capable 3L V6 plus twin small turbos that make for quick spool up I suppose helps.
You definitely notice the lack of quick heat soak and timing being pulled with a larger inter cooler.
