Hey All!
Steeda just released a bunch of products for a few different applications, including the Explorer ST!
Introducing the Steeda Adjustable Front Sway Bar (2020-2023 Explorer)
Designed to reduce body roll for more neutral handling, allowing you to carve corners, while the 3-way adjustability lets you fine-tune the sway bar stiffness to meet your needs and provide the control you want. CNC-machined billet steel ends offer greater strength than the coined ends on other bars.
- Made in the USA
- Neutral and flat handling
- Reduced body roll
- More control with heavy loads
- Maintains a comfortable ride
- 1.375" solid steel sway bar
- 3-way adjustable
- 32.5% stiffer than the factory sway bar
Check it out here!
https://www.lethalperformance.com/s...-sway-bar-2020-2023-explorer-st-555-1037.html
Check out all the new Steeda Products here!
Steeda Quik-Latch 1.75" Low Profile Hood Pin Kit
Steeda Quik-Latch 1.75" Low Profile Hood Pin Kit - Machined Aluminum
Clutch Spring Kit for Bronco
Steeda Clutch Spring Kit (2021-2023 Bronco)
Of course, if you have any questions, looking for something in particular, or want to get something on order, feel free to reach out to any one of us here at Lethal Performance!
