How-To: Swap Bench 2nd row to Captains Chairs with Console
#41
So I have bench seats in my '23 ST. On the fence about them but i'm discovering my youngest (7) likes to get into the 3rd row by jumping over the 2nd row seating.
What's the difference between the bench seat outer seats and the captains chairs? I've been trying to look at photos but are they the same seat other than the armrest and the lower bolstering/stitching design? I'm wondering if i could make due just pulling the middle seat and installing some temp carpeting and the cupholder console temporarily. At least then my youngest has a path to the rear seat.
Not sure i want to commit to the full captain chair swap yet as my oldest will be driving soon so there may not be a need to access the 3rd row, in which case I can leave those seats down fully and be fine with the bench.
Yeah that would work. Probably wouldn't look the best, but it would work.
KoolAl44
Alabama
2021 Ford Explorer ST
#42
@bguild I have to thank you for your amazing write-up! You gave me the confidence to purchase a 2021 that just came off lease, even though it had captain's chairs when I needed a bench seat. To your point, I can confirm that swapping captain's chairs for the bench seat does work!
The downside - I just discovered - is that I got the bench from a 2020 XLT, which does not have the powered fold-down feature. In and of itself, I'm not too bothered by that, but, it lacks the wiring harness and control unit that provides power to the rear-folding seats. I did not realize this while I swapped all the seats, and now my 3rd row is stuck in the flat-down position.
So, I'm going to have to get the harnesses reconnected so I can put the 3rd row upright. And then, I need to decide how to proceed. I'll either remove the unit from my captain's chairs, or find what I need from a junkyard for a reasonable price. (I plan to put the captain's chairs back in someday when my kids have grown up enough that I don't need 7 seats.
I did manage to get the seats for only $213, so I can't complain about the cost. And the work only took me a few hours today.
What was your solution. I just did this exact thing and was going to transfer the harness from the captain chairs to the bench
Adewale
canada
2023 Ford Explorer
#43
2) Unbolt 2 front (13mm) and 2 rear (13mm) for the drivers side and passengers side 2nd row seats.
Hello, please by chance do you still have the seats removed after you moved to captain seats? i just got a an XLT model from auction but its completely missing all the second row seats.
#44
Just an FYI, the bench seat wouldn’t match the rest of the seats in your XLT.
Adewale
canada
2023 Ford Explorer
#45
Seems the same to me; the interceptor models don't match due to its bolts tying positioning but looking the positions and bolting of the pictures you attached, they do.
#46
No, they’ll physically fit but the upholstery is different.
Adewale
canada
2023 Ford Explorer
#47
I understand the leathered works maybe(infact differ), as far as they fit and both front have leather seats, they are fine by me.
#48
Just to update my own question, this is what I ended up doing.
4 bolts and you can remove the center bench. The tricky part is removing the trim covering the bolts, and getting at the front two bolts. It can be done with the side seats in without too much fuss and the right combo of tools. Remove the bolts, unplug the single wiring connector, and flip the seat up and back to the 3rd row (seats down) and out.
You WILL get a seatbelt warning however with the middle bench removed. What i did was remove the belt buckle and intermediate harness under the seat and plug it into the body harness and just tucked it under the side seat. Will come up with something for this later.
This is what it looks like with some aftermarket floor mats for a 6-seat Explorer. Biggest difference from captains chairs is the lack of the middle armrests. My kids don't mind. Does give more room for passing through.
If i need the bench seat, i remove the 3rd row floormat, and reinstall the center bench again. Takes me about 15-20 mins to do. Longest part is the stupid buckle and wiring harness.
#49
EDIT: There's an easier way to do this with ForScan. See a few threads down
Just to add more data. If you previously had a bench seat and swapped to captains chairs, i'm sure you've discovered the warning you now get on the dash for not having the middle seat installed. I imagine most folks doing this trade want the bench to have the bench buckles otherwise the seat is unusable. So if you traded for captains chairs, you need to plug a buckle in.
Found the part numbers for just the buckle for the center bench section. You'll likely want the black but i'll list the sandstone one anyway.
Black: LB5Z-7860045-AA
Sandstone: LB5Z-7860045-AC
At this time they are about $33.
Intermediate harness appears to be part number L1MZ-14B509-BA. Looks to be about $43 or so.
The above part isn't confirmed, but visually appears to be the same. I just don't want to spend $43 (plus $15 shipping) on a wiring harness for the plug end so I will likely search for a junkyard part just for the plug. If anyone decides to buy this, just keep in mind i haven't 100% confirmed this is the correct wire, but I am 99% sure.
I actually have removed and installed my center bench section and the longest part of this is fishing the buckle and wiring harness in and out of the seat. So looking to make a quick plug-and-play solution. Essentially 4 bolts and unplug the single wiring connector and plug in my dummy buckle.
Boston
2025 Ford Explorer ST-Line
#50
That’s a nice project. I would trade my OEM captain chair with you for your bench seats. I got my 2025 ST-Line with the pano roof and there’s no option to have both (pano roof and bench seats) and I would love to have both on my vehicle.
#51
Thanks but I'm not looking to swap. I actually like the ability to swap from the 6-seat layout to the 7 seat if needed. I prefer the bench, but my kids prefer the middle seat out.
#52
Digging it into this more, i have discovered that you can make the seating config change through ForScan to prevent the seatbelt warning from going off. (At least for '20-24)
It's in the IPC. It's a drop down menu built into ForScan already so no need to look up lines of code.
In the IPC module, navigate down to "Rear Belt Monitor Seating Layout" and switch your layout to what is appropriate. So if you have a bench and are going to captains chairs, switch from option 4 (2-3-2 seating) to option 6 (2-2-2 seating). Write the changes and restart and that will eliminate the warning without the need of plugging a buckle in.
I do not know if the wiring is present in captains chairs vehicles so that a bench can be swapped in, plugged in and the seat belt minder made functional. Someone else will need to confirm the wiring part, but you can change to option 4 in forscan to get that middle seat functionality if this is the case.
a-hubs
IL
2021 Explorer
#53
I have a 2021 XLT with captains. What are the chances I can just remove the arm rests on my captains chairs and drop the middle part of the bench seat in between?
texas
2016 explorer
#54
i would like to put the captains chairs in mine. if anyone in Texas wants to swap my bench for captains chairs let me know. i have pictures of the bench seats.
