How many people have had driver side heated seat issues?
Swapped the heating pad a year ago... probably at 85k miles. Not too hard and the heating pads are cheap.
WillZhai
Toronto
2020 explorer
Same here, only costs 25 cad to order the element. Take me three hours to replace it. (Tips: alcohol can help when removing the old mat) This is the first car I have had a heated seat issue. My old 2013 Fusion has a much better build quality than my 2020 Explorer.
The thermistor in my heating pad disengaged, causing the pad to desolder after heating up like crazy. Ford simply used hot melt adhesive to hold it in place. The new heating pad seems to be better quality hopefully I won't need to replace it again.
edog
PA
Been back to the dealership twice for the driver's heated seat not working. At first I was told it was the module, which they replaced. It didn't fix the problem. Going back to have the element replaced. All other seat functions worked, before and after the module replacement.
bigspoon86
arizona
2020 explorer st
I was just getting on here to literally ask about this same issue. My 2020 drivers side hasn't worked since I got it a month ago I took it in and they wanna do diag first but won't offer a rental till they determine if its warranty work
edog
PA
An update, the heating element was replaced and the heated driver's seat is working now.
#26
My 2016 drivers side went out a year or so out of warranty and my dealer wanted $1600.00 to repair it!
Navylew98
Denver, Colorado
Can you share where you bought the heating element and where you found instructions? Thanks
EDWYER
#28
No issues, close to 130k miles.
