High beams no longer work
tigerST
My 2020 ST has been fairly solid since I bought it. This might be the worst issue I've had... NM that's a lie. The freaking seal on the fixed moonroof glass is the worst thing. lol
Not sure where to start since there isn't a high beam fuse. I haven't found any posts with this issue either.
I did setup BAMBI or whatever via Forscan over a year ago. I did have to up the power to the DRLs after replacing a cracked headlight to stop the flickering. I think this might of been caused when I disconnected the battery for a while I was upgrading my brakes to the Superforged (I think I know why people have trouble bleeding these brakes). Anyways any suggestions on what to look at is appreciated.
New Jersey
2017 Grand Cherokee
I would start by going back to factory BCM flash even though it’s been over a year Electrical sucks and 1/2 the time the fix will be something that doesn’t make sense or is literally powering off and back on
FYI the seal on the pano roof is a wet seal. It leaks by design.
