Help with massive coolant leak please
Justinbeez
California
Issue resolved.
J
Justinbeez
California
Idk why but this seemed to either have blown off or no clue why I would even take that off as it wasn't in Houstons video I followed to the T.
J
Justinbeez
California
So after more research, I found an olllldddd thread of some clamps blowing, I believe one other person showed a picture of the same valve but not naming that specific location. It's on the driver's side, just above the alternator. Does anyone know what that leads to?
J
Justinbeez
California
After tightening everything down, finding that coolant hose popped off, still sounds like a rattle or flutter under driver side door. I have an AWE catback so the flex pipes shouldn't be an issue as those are replaced. I'll attach a video. This is my first vehicle with turbos so im not inclined to all the sounds that could happen from them IF that's the case. Could just be exhaust rattle and I need to have the shop tighten them back up, could be the compressor winding down. Not sure if adding an intercooler would create a noticeable noise from down below with increased air flow? You'll hear the sound mid to end rev.
https://drive.google.com/file/d/1HneUbSZH1wj6dqQgoHjAspCUxL-aHZtz/view?usp=drivesdk
Sounds normal to me. Intercooler should not add any noise.
