Hard shift 3rd to 4th gear + 91 vs 87 octane
Pyro
Firefighter
Ontario california
I have a 2022 ford explorer st. I always warm up the car before taking in for a drive. I have noticed that when in sport mode the car has a hard shift from 3rd to 4th gear it feels like it's going to miss the gear depending on how hard I throttle it. It happens only on the initial drive when I first take it out and after that it doesn't do it. Not sure what the issue is or if it's even normal.
Another question is should I be putting 91 octane or is it safe to use 87? I've been using 91 for a bit ibwouldnt mind dropping to 87 not sure how the car would react
Zim
Don’t use 87.. It’s a performance SUV man lol.
Mine runs fine on 87 octane. The cost is so much less here it just makes sense.
LA, California
I was also mixing it up, until I went for ST experience drive. When I asked about it to the Ford performance team, they suggested premium fuel for the twin turbo engine. Now I fill only premium, but I don't notice any difference between the 87 and 91 on my daily drives in LA.
Pyro
Pyro
Firefighter
Ontario california
I figured. I'm sticking to 91 was just confirming since it only show that 87. THANKS!
Never mind the octane. A hard 3-4 shift is not normal. I'd get that checked out.
AirRick
Tennessee
2022 Ford Explorer King Ranch
I have a 2022 King Ranch 3.0L, and I have the same problem no matter what fuel I use when it nearly misses the 4th gear shift almost every time. Brought it to Ford and they reset the electronics (whatever that means) and it worked fine for a few weeks and it started happening again. It seems to be an electronic problem rather than a mechanical problem. I wonder if there is a tune that will clear this up? Any thoughts or suggestions?
Sport was a little wonky in this thing before tune, and was in both my Edge ST's. On the tune, it actually made Sport hit pretty hard, but I've worked with ZFG to get the shifts eased up, and Sport is coming along nicely. So yes, you can get the shifts tweaked to your liking with a tune. The last one I have given me some issues with is the 4-5, which is too hard under normal acceleration, so much stands out from the other shifts. When I send my logs back in, Im going to ask to take some heat out of that one, and I think we will be done.
Wisconsin
I have a 22 ST as well. Look into the 10r60 transmission CDF drum failure. They all have this problem. Mine shifted hard and I had a new transmission installed. Hard shifts gone.
