Grill shutters
N1teM4r3
Bronx
2020 Ford Explorer st
The transmission in my 2020 Explorer st has been rebuilt and replaced at least 4 times. This latest transmission repair lasted about 3 weeks before the car started jerking. I towed it to the Ford dealership that did the repair. Now they're saying it's because my grill shutters aren't working and want me to pay $3,000 to repair the shutters. I can't find anything online that collaborates Ford's diagnosis or price. Any advice?
So let me get this straight, the dealer is saying that the shutters are the problem why the transmisssion is jerking?
Yea…that’s not right.
Maybe, and a very big maybe, by the shutters not opening, the fluid is not being properly cooled which is causing the transmission to overheat? I know it's a very long reach but maybe that's what they are trying to say.
The car would throw a fault code though if the tranny was overheating.
I was assuming it did. OP didn’t mention there were no codes and I don’t think all transmission codes will cause a CEL. I was just trying to come up with something, anything, that might be plausible. LOL!
N
N1teM4r3
Bronx
Yes, says grill shutters don't work car is shutting itself down. I still don't get it or believe it
N
N1teM4r3
Bronx
I'm crying too, with laughter! Tasca Ford in Yonkers?? Actually I think all Ford dealerships are shady at this point. I don't know about codes but Ford said when they put it on whatever only a code for the grill shutters come up. 2 weeks after I picked it up all kinds of warnings kept popping up in that box on the dash. But no check engine or wrench
N
N1teM4r3
Bronx
KCM
Nebraska
Doesn't the tow screen in the cluster have a temperature gauge for the transmission? If so, would be an easy check to see if the temperature is high when it starts to jerk.
Charlotte
2024 Explorer ST
If the shutters were malfunctioning causing overheating, the entire vehicle will be in an overheat state, not just the transmission as the trans cooler is in the cooling circuit.
WileyRG500
Greensboro, NC
2021 Ford Police Interceptor Utility 3.0l Twin Tur
I'm sure glad mine doesn't have the shutters and still average 20.9 mpg in mixed driving.
Webb City, Missouri
2022 Ford Explorer King Ranch
I used Forscan to monitor the bank A & B shutters on my 2022 King Ranch. No matter what the engine temperature is, the B shutters never move off 100%. The A shutters start at 0% then move to about 45% and just sit there no matter what. I don't see any codes being thrown but wonder if they are working correctly. Do these things get sticky and need some lube?
Rhino
Bay Area
Like others have stated you should get a check engine light or fault code and/or trans temp warning indicator. If the active shutters are closed then no airflow. Bottom line is they should have found this earlier and you should not have to pay. I know all this because it’s my job. I have a 2020 ST with Ford tune and drive it spirited for sure. No trans issues at 45k miles.
