Fuel Pump Control Module
Eric_Tilton
Louisville, KY, USA
202 Explorer ST
Anyone know the location of our fuel pump control module?
Sacramento, CA, USA
Removal
All Vehicles
  1. NOTE: The fuel pump driver module is located on the bottom side of the left front floor panel, above the sound insulation panel.
    For fuel pump driver module component location view.
    Refer to: Fuel Charging and Controls - Component Location (303-04A Fuel Charging and Controls - 2.3L EcoBoost (201kW/273PS), Description and Operation).
  1. With the vehicle in NEUTRAL, position it on a hoist.
    Refer to: Jacking and Lifting - Overview (100-02 Jacking and Lifting, Description and Operation).
  1. If equipped, remove the fasteners and position the front of the shield down to access the fuel pump driver module.
Standard fuel pump driver module
  1. Disconnect the fuel pump driver module electrical connector.
  1. Release the fuel pump driver module retaining tab and then remove the fuel pump driver module from the bracket.
Heavy duty fuel pump driver module
  1. Disconnect the wire harness retainer, then disconnect the fuel pump driver module electrical connector.
  1. Remove the fuel pump driver module fasteners, then remove the fuel pump driver module.
All Vehicles
  1. Only if needed, remove the fasteners, then remove the fuel pump driver module bracket.
Installation
All Vehicles
  1. Install the fuel pump driver module bracket if removed, then install and tighten the fasteners.
    Torque: 97 lb.in (11 Nm)
  1. Install the fuel pump driver module, then install and tighten the fuel pump driver module fasteners.
  1. Connect the fuel pump driver module electrical connector , then connect the wire harness retainer.
  1. Install the fuel pump driver module to the bracket until it clicks into position.
  1. Connect the fuel pump driver module electrical connector.
All Vehicles
  1. NOTE: The shield needs to be installed underneath the fender splash shield.
    If equipped, install the shield, then install and tighten the fasteners.
    Torque:
    1, tighten to: : 22 lb.in (2.5 Nm)
    2, tighten to: : 53 lb.in (6.0 Nm)
    3, tighten to: : 53 lb.in (6.0 Nm)
    Torque:
    Screw and washer, tighten to: : 22 lb.in (2.5 Nm)
    Nut and washer tighten to: : 53 lb.in (6.0 Nm)
Nicholemo
Ford explorer 2021 XLT
Hey there!!
Did you find the FPCM?
Are there pictures in the reply above that haven’t shown up on my phone?
And when you say left front control panel are you talking about under the drivers side or passenger side?
Nicholemo
Update!! Thank you soooo much!! We just saved a couple hundred and fixed it ourselves. Took about 15 minutes! The FPDM is in the same spot on the 2021 Explorer XLT in case anyone’s looking!
