Front Struts
ARC
Oak Lawn, IL, USA
2022 ST Black
Just got in the new OEM replacement struts for the front.
Anything else I should look to replace at 72k ?
Maybe strut bearings as it is making a clunking noise?
Does the strut mount need to be replaced as well?
The shop doing the work said they often need replacing.
I only bought the strut and not the kit because I have Eibach's on the car.
Thanks for the input on this.
Strut bearings are super cheap, there’s no reason to reuse old ones. The only reason a mount would need to be replaced is if you strip a bolt. It’s just a chunk of metal.
