Forscan to enable more info on gauges?
BoostIt
Wisconsin
2022 Explorer
I went through and enabled the oil temp, coolant temp and boost gauges in forscan. However, it has made no difference on the cluster. I know coolant temp is being sent to the display because the silly bar slider is there.
Is there any way to make the display show the actual coolant temp?
Ideally I want to know coolant, oil and charge temps as well as boost on the dash...
There is no boost gauge.
Honolulu, HI, USA
It would be nice to have a multi-guage display on the center screen while in Sport mode showing actual batt voltage, boos gauges for each turbo, oil press and temp, collant and trans temps. All the info is there being fed into various MCU so having on screen shouldnt be that difficult to program.
