You don’t need to go through spreadsheets anymore. If you go in not as “Built As” all the options will be listed and you can just click “Enable or “Disable”. My subscription ended so I can’t show you in detail but I can kinda guide you as to where to go. I’m not sure how familiar you are with this so I’ll just go over basic start and steps.
- Open connect your OBD link or whichever you are using to your car. Then open Forscan. I used a laptop.
- Next in the bottom left hand corner there’s an icon you click to connect to your vehicle. Click on it.
- It’ll put up a reminder to have the Ignition in the ON position. Just click “OK”
- next it may ask you if want to optimize max performance of the obd adapter. I click “Yes”
- next if it’s your first time it will have you create a profile for your vehicle.
- after that’s done it’ll run a diagnostic and it should say “Ready” at the bottom.
- next do you see the 3rd icon up from the bottom on the left bar? It looks like a microchip. Click on that and it’ll pull up all the modules.
- Choose which module you want to look in and at the bottom left corner again there’s a “Play” looking icon, click on that to bring up a list of the options you can “Enable” or “Disable” for the module you want to look in.
- after enabling or disabling you’ll have to save the changes by clicking on a “Write” icon i think it was.
- After you do that it will prompt you to turn off the ignition and turn it back on.
- to disconnect look at the very top icon on the left bar it looks like a car. Click on that and at the bottom where you clicked the connect button, to the right of it is the disconnect icon. Done.
