Ford Performance Exhaust
Dang 2100 is ridiculously high. I’ll get a thermal and Downpipes for that price.
As UNBROKEN mentioned, looks like a Borla system from the side by side photos. Ford on the left and Borla on the right. ~$200 cheaper direct from Borla.
Oh then that isn’t too bad especially if you can use FordPass points.
Kirk ST
Pittsburgh, PA, USA
Borla like all the rest.
Always appreciate your comments on here!!
Will this sound like the Borla 2.5" setup they sell? Is there ANY reason I should buy the Ford one vs. one directly from them? Thanks!
Unless you have FordPass points to use then there is no other reason to spend more.
All Borla systems are 2.25” like factory and the Ford kit will sound just like the S Type that it is. What Borla does NOT include is a mid-pipe with flex sections built in and I think everyone knows the oem flex pipes WILL fail at some point. I wouldn’t recommend any aftermarket kit that doesn’t include a mid-pipe but at the very least you can but mid-pipes alone from Lethal.
South Carolina
What size is the stock exhaust? 2” or 2.25”?
