Fitment question: 22x10.5 +40 w/ 295/40/22 Will they fit?
Mr.Solis
Meridian, ID, USA
Hello all,
need some help on fitment, particularly on inner clearance around the struts.
Will 22x10.5 +40 w/ 295/40/22 fit front and back?
I have 1/4 inch hub centric spacers if needed but I am concerned with the wheel stud length. Anyone have experience with spacers on original studs?
92onward
Active Duty U.S. Navy
I think your magic offset for 22s is +30
+40 will work but will be fairly close to the strut...well the tire sidewall will be anyway especially with a 305.
+35 is better obviously.
+30 is getting into custom made wheels but is perfect for a flush fitment.
1/4” slip on spacers are fine on stock studs just make sure the center bore is large enough and make sure you buy billet, not cast aluminum spacers.
Steeleville, IL, USA
Don't mean to hijack, but I got tired of searching these threads. Do you think a 20x10 wheel with +40 offset will be okay in the rear? Would most likely run a 295/45 tire.
+40 is a bad offset for these things on 10 or 10.5” wheels.
