Exhaust on Cold Startup
pryan
Swanzey
I have a 2021 with just over 14,000 miles. Because it’s cold in the morning, I will often start it and let it run for a few minutes. I’ve noticed that it produces what seems to be an excessive amount of exhaust.
it’s white, and appears to have a sulfur sort of smell. In other words, it doesn’t seem like it is “burning” anything. But, I don’t think I’ve ever had another vehicle that seems to produce that much exhaust even on a cold morning.
I’ve seen posts about exhaust after sitting, but this is something that happens every day. Any ideas?
It’s normal…and worse in cold weather.
Yellowknife, NT, Canada
Same thing here at -25 to -35 C. I am not noticing the sulfur smell.
pryan
pryan
Swanzey
It’s not really strong.
I did a quick web check... "broken or leaking catalytic converter " could cause that type of smell.
In cold weather you can see exhaust leaks very clearly. Anyway, something to look into.
In cold weather you can see exhaust leaks very clearly. Anything something to look into.
Normal smell on a cold start…as is steam coming out of the exhaust. The colder it is the more steam and the longer the smell will last.
pryan
pryan
Swanzey
Thanks folks. That’s comforting.
Mine got worse and worse since the first year and at 3 years had my catalytic converter replaced on the driver's side. Now I'm happy to report no more exhaust smell even on cold days.
