exhaust and wheels?
fort lauderdale
2021 ford explorer st
Does anyone have any good recommendations for an aftermarket exhaust and wheels for my 2021 explorer ST, roughly 10k miles. I want to get a tune after I order these things. Hoping to bump the HP up a bit, Thanks everyone!
Both have been discussed ad nauseam…use the search tool and you’ll find hours on hours of reading.
W
fort lauderdale
okay, thank you
Treasure Coast, FL
2022 Explorer ST (AWD)
@willh876 Hello there fellow FTL neighbor. Just relocated myself from Davie to Stuart. Thermal R&D exhaust seems to be a wide favorite on here since it also includes mid pipes. I personally went with Borla exhaust which does not include mid pipe replacement. The reasons why even care about mid is because stock will rattle after some time.
W
fort lauderdale
Hello, Stuart is an awesome place! Very peaceful, good golfing as well. I have been doing some research all night and I have read a lot of what you just said. I see the top two are the exhaust you mentioned. I appreciate your input and response, let me ask you this? I have been looking at rims for the car. It seems like a lot of rims are different sizes than the OEM rims that come with the car. My rims are the silver ones and I wanted the black ones like you have in your photo. But if I don't get them it looks like the rims are different sizes and you would have to get new tires as well. Any idea? Thanks agian
Treasure Coast, FL
Yes, that's correct. The black rims are included dependent on which package you selected for example (Performance or Street). This will determine if you get 21in black rims or the 20in. if you desire to keep your tires then it's possible if you get the black rims at same rim size. Some on these forums have done what you're inquiring about. However, if you choose to go bigger rims then Yes, you will need bigger tires. Hope this helps
W
fort lauderdale
Hello, Thank you sir, it helped a lot.
Colorado Springs
21 Explorer ST
I bought the thermal 2.5 cat back. It sounds amazing without being too loud. The black tips are a winner in my book also. Took longer for removal of the stock than to install the new also.
W
fort lauderdale
I'm going to purchase the thermal as well. I cannot wait until I can get it put on. Does it get louder in sport mode or is it the same in every mode, obviously depending on how hard you push it?
Colorado Springs
21 Explorer ST
I disabled the fake engine noise. It gets loud at cold start and under heavy acceleration. Otherwise there is no difference in sport... Which I use 100% of the time outside of short jaunts.
W
fort lauderdale
Good to know, than you. I need to really read this manual. I had no idea they had such a thing as fake engine noise. Any other key features you recommend?
Colorado Springs
21 Explorer ST
The fake engine noise gets turned off in Forscan. I made some other personal changes like Bambi mode and changed the DRL to the amber lights.
Western New York
20' Explorer ST
Did you use a spreadsheet if so which one?
