Excellent Cheap Cargo Liner
Buffalo, NY, USA
So if you are in the market for good cheap cargo liner to haul tools, metal, anything sharp, etc in your ST, check out a Horse Stall Mat from Tractor Supply. The 4'x6' size fits perfectly in the back of the ST with the seats folded down. It is thick and heavy!
And it's only $55!!!
I bought it for a different reason, but now thinking of buying another one and cutting it to fit with the seats up!
Jeppo
Davidson County, NC
Will it fold to be vertical if you put the second row back up?
D
Buffalo, NY, USA
No,it is too thick. I think I would cut it to length when the seats are up, and just put the piece in when they are down. You also might be able to slice it most of the way through to allow it to bend.
Routering a channel, yet still leaving it connected might do the trick.
D
Buffalo, NY, USA
Yes! I cut it in half with a sawzall for another project here. The back side is knobby, so you could use it that way so stuff doesn't slide around.
