DTC P0299
OREGON
2022 ST
I am getting the code on heavy pulls. It means lack of boost. Has anyone been getting these? I do have a tune but, appears regardless of stock or tune.
Nope. What other mods do you have?
ST PETE
OREGON
2022 ST
Just running the Afe CAI. Thinking of bigger intercooler and charge pipe. Need to have the turbos checked for leaks.
Planet Earth
Did the code start shortly after your afe install?
ST PETE
OREGON
2022 ST
I had the CAI installed shortly after I took delivery of the ST. I then got a tune from Monster and that is when it showed up. Even after going back to stock, the code appeared. I don't think the Monster tune has anything to do with the code but, it could because it requires more boost.
Planet Earth
I am also running the Monster Tune.
In addition to the obvious turbo failure, an under boost code can be caused by a leaking charge pipe, clogged intake and sticking bpv. May be worth a quick double check of those too. Otherwise will need a more indepth diag for sure.
Yeah, since it happens with a stock tune, definitely check your intake install. Many have had codes related to the install.
ST PETE
OREGON
2022 ST
If anybody cares about my boost lose, the charge pipe to the intercooler had come apart slightly which caused boost lose. After attaching, all good now. Pedal to the metal...
