Dragy app vs others
dousman wi
2022 explorer st
Just curious if anyone has compared the dragy app with other apps. I'm trying to justify spending the $160
blackdog
MA
I bought a dragy last month and still need to put it in the truck. As far as a comparison is concerned I bought the dragy because supposed to be more accurate and have more features than the competitors. I like the size, the way it works, and the apps. we'll see what the future brings.
Columbus, OH, USA
I have compared it to the cheap phone apps, those are off by a random number of tenths. Also have compared it to the racebox mini. Racebox was fairly close but had a 1' rollout setting that you could check and uncheck that would then change your times.
Dragy vs time slip I have tested hundreds of times, it's 99% within six hundredths, although this year it seems to always be within 3 hundredths.
phone only based apps won't be accurate as cell phone GPS refresh rate is 1Hz, or 1 sample per second. I believe the new Draggy units are 15-20Hz. P-Gear is 20Hz, Racebox Mini is 25Hz.
