Door key pad on pillar
Iowa
2025 explorer st
I have a 25ST took it to the Ford dealer to have the pillar door keypad put on that’s an option you can order. They’re telling me that they can’t put it on that. It needs some other type of relays and activator to get this to work but on the Ford accessory thing it says it’s for 25. Has anybody come across this?
BS. you just replace the trim and attach the electrical connector--it's in the Workshop Manual. Then program it to BCM with FDRS.
Can it be programmed with ForScan so that you don't have to involve the dealer at all?
What they said. I had mine added before I took the car home.
H
Iowa
2025 explorer st
Thanks I’m going to talk to them
5here have been people who have tried but I don't know if anyone has been successful with Forscan. In FDRS it's a toolbox routine under BMS.
H
Hichie
Iowa
2025 explorer st
Thanks for all the comments. The dealer just called stated the fuse was blown and it works now but thanks for all the input.
