Clicking sound when turning wheel…heard after truck heats up
Hollywood, FL, USA
when i turn the wheel on my 2020 Explorer ST there is a clicking sound. It happens when the car heats up. My truck is back in the shop for 2nd time, but they still can’t figure out the problem. Any thoughts? I asked ChatGPT and found these results.. Thank you!
https://chatgpt.com/share/7f86069a-13be-4a42-b17f-d347bba5b68f
This is a somewhat common problem I believe coming down to the washers on the axle bolts.
roycereal
Rosbery Australia
i second what @2020FordRaptor mentioned regarding the washers on axle bolts. saw a similar issue with my friend's Explorer. might be worth bringing that up specifically with the mechanics.
WarST
Hollywood, FL, USA
The ford mechanic is replacing the 2 front axels...they think that's the problem. If that doesn't work...I'll definitely mention the washers on the axle bolts! Thank you!
4 Main Street, Wichita Kansas
did you get that done under an extended service plan? And did it fix the issue? I definitely have that but swear it's coming from the rear
Farmers Branch, TX
I've noticed the same thing recently on mine. I only hear it when I'm driving up through the parking garage here when making right turns to the next floor. Going down (and making the same turns but left) I don't here it. I haven't had the chance to crawl under and take a look.
