Charging with a charger in garage
QuickRick
Capital Beltway, MD
Guys and Girls, We have a 2025 ST that we bought to leave in our Florida home garage. I’m getting a message off of FordPass that says “ battery saving mode” despite having a maintainer/ charger attached and **working. In fairness I can’t see the connection as we are 900 miles away. On the F150(we have one) Forum I was told that it matters which side of the cable you apply the charger. Do you think that this means the vehicle does not see that charger? Kindly chime in! QuickRick ** at least I believe
Jeppo
Davidson County, NC
I put a 1amp maintainer on about once a week. I’ve noticed FordPass doesn’t recognize the battery becoming fully charged until I next start the vehicle.
Only explanation is that the battery maintainer is not attached or is not working. There should be no reason why you should get that message with a working battery trickle charger.
I believe if the vehicle is not started over a certain period of time, the vehicle automatically goes into a deep sleep mode (AKA battery saving mode). I do believe this is regardless of having a maintainer on it or not.
J-Dub
Buffalo NY
2021 Explorer King Ranch
YES SIR U must put Negative charging lead(clamp) before BMS sensor. Not directly to Negative battery terminal , or ur right , computer is not even seeing tender/trickle charger ! There are a few good vids on YouTube about this exact scenario. Best of Luck
QuickRick
QuickRick
Capital Beltway, MD
J-Dub
I think thats it. Cool would be if I could remote start but so far I'm failing doing that.
QuickRick
Kansas
2022 Rapid Red ST
Regardless of charging status, the car will go into battery saving mode after exactly two weeks of non-use. It will send a message when it does that. After that it can no longer send/receive messages or commands because the modem shuts down. That mode will continue until the car is restarted.
