can I use the roof rack holes for a CB antenna mount?
Somalia
dont have the rack, is there something under the panels I can use to mount a CB antenna?
Not likely. The trim panel has studs on it that bolt through the only holes up there.
Sgt1411
BC&AZ
Antennas are a big part of the Police upfit, Ford Engineers have looked at the structures of the roof aluminum and supports. I would recommend you read through the Ford Police Interceptor Modifiers Guide before adding anything.
riverbadboy
Laughlin, NV, USA
I don't think so, when I removed the rails and installed the ford factory moulding the holes were used for the new moulding.
Sent from my SM-G955U using Tapatalk
