CAMBER FROM LOWERING SPRINGS / DOWNSHIFT SURGING
Fresno, CA
2022 Ford Explorer ST - STAR WHITE
I installed a set of Steeda lowering springs about a month ago. I noticed a slight camber - approx 1.5" - 2" in the back, leaning in on top.
I contacted Steeda to see if this is normal, but haven't gotten a response. Sent them my alignment results, and they show the alignment is within specs.
I was curious if anyone else has had this issue, and knew of anyone that makes a kit to adjust the camber to bring the wheels into a straighter look?
On another subject. Has anyone else experiencing a surging as the car is slowing? It happens as the RPM's go below 2000, then surge back up to approx. 2200. It only does this below 30-40 miles per hour.
You don’t need a kit for rear camber…you need a competent alignment shop that knows where the adjustment point is.
My rear camber right after installing the Steeda springs was -1.7 degrees. After the alignment it's -0.6 degrees. As @UNBROKEN said, get a competent alignment shop. Steeda could care less about your alignment; they made a quality part that fits, and it's your job to get a proper alignement.
MR COOL
Fresno, CA
Thanks for the response. You have been very helpful.
MR COOL
Fresno, CA
Thanks for the response. You have been very helpful. I am very happy with the Steeda products (sway bar and springs) .I contacted Steeda because I didn't know where else to start. My alignment shop gave me about the same numbers as you're showing. At $400+ each for tires,I don't want to shorten the life of my tires.
So go back to your alignment shop and tell them to set rear camber at -.5°
MR COOL
Fresno, CA
I have an appointment for next Tuesday at a different shop. Thanks for all the help and advice.
Charlotte, NC, USA
Unsolicited suggestion, but I'd wait another month to be sure you're springs have fully settled. When mine were first installed they fell within specs, after time and miles, tire wear told a different story.
MR COOL
Fresno, CA
It’s been a month +. Do you think I should wait 2 months?
