Bolt pattern and TPMS for 2020+ Explorer?
Calgary
69 Mach 1
Hi,
I’m looking at buy a used set of winter tires for my Explorer ST. The ones in question are 245/60R18 mounted on police steelies from a 2017 Explorer.
Google tells me that the 2017 and 2020+ explorers share the same 5 x 4.5 bolt pattern, can any confirm this?
Also does anyone know if the TPMS sensors would be compatible between the two generations?
The older Gen share a bolt pattern but not the hub bore size. Older wheels won’t fit 6th Gens.
And any 315mhz TPMS will work.
Western New York
20' Explorer ST
Do you have any recommendations to where I can grab those interceptor wheels for the winter use? Or at least have something aftermarket that is within the $100-120/wheel?
Get the cop car wheels from a 2020 or newer.
Winnipeg, MB, Canada
Canada, they can be around 100$ CDN per wheel. You can negotiate for lower usually, around 90$. Dealer cost is 47$ per wheel.
Western New York
20' Explorer ST
Agree. But right now I've only found $175-200 per wheel for those cop car wheels. (2020+).
If I went aftermarket for winter set, what are some recommendations/sites?
