It depends on what you want to accomplish, and whether you're tuned.
For example if you want the best gas mileage, the 0% ethanol gas is best since there are more BTUs per gallon.  However, in my location I also have access to 93 no ethanol gas- it's about 15% more dollar-wise per gallon which does NOT justify the extra .5 -1 mpg highway.   A tuned engine is not going to show any measurable mileage gain- part throttle operation is based on spark advance, not airflow.  The ST base algorithms are designed to try and optimize spark advance and as far as I know, you can't actually "tune" an effective "lean-burn" strategy.
In terms of performance, the higher the octane in an untuned engine, the better, but once again the difference between 91 and 93 is negligible and has much more to do with ambient air temperature.
In a tuned engine, where the boost pressure/air density can be increased, the increased cooling of ethanol additives (say a 93/10 mix) might actually be able to provide a bit more power than a 93/0 mix.  You will be burning more of the former which makes up for the BTU content.
