Best Downpipes out there?
dorian!
I was looking to do a little upgrade to my car and get downpipes.
I've been looking around and I came across with these 3 options:
1. FENFABrication
2. SPD Performance
3. CV Fabrication
What would be the difference and why the prices are different? do they perform better?
Thank you.
D
dorian!
The absolute best will be any of them using GESI G Sport cats.
If what you really mean is what’s cheapest…CVF with a discount code from Tyler Clark.
All will perform the same…build quality is probably the best with FenFab but anything that needs a defouler is NOT emission compliant….only G Sports are certified.
1. FENFABrication
2. SPD Performance
3. CV Fabrication
Thank you.
They all perform the same. It’s just the quality, although the differences might not be worth it for most people.
I would stay away from any requiring defaulters as mentioned. You can also have them ceramic coated if you want to improve heat.
Chicago
2020 Explorer St
I have spd's didnt have any complaints with them until I snapped one above the cat on Monday. I made a post on it haven't heard of this in any other cases but thought I'd share.
You also modified them and welded on them. Can’t lay that break at SPD’s feet.
Chicago
2020 Explorer St
Yes correct the only modification to them was I had a vband at the very end of them welded on where they meet the mid pipes. I'd say this is more of a product fault specially after speaking to customer service saying it was a known issue with their version ones and how clean the break was. These are the version 2 with the flex section directly on the DP and yet still broke Ill be pulling them of this weekend to inspect better but it looks like the weld did not penetrate. I'm not saying this is the case with all gen 2 SPD downpipes but this particular set seem to have been flawed due to the nature of the break.
