Battery going dead
Pacific NW, USA
Anyone experiencing issues with the engine battery suddenly going 100% dead overnight? Jump starts easy and performs fine for a time...and then repeats. No check light, no codes, no explanation, no pattern? Had techs plugin and found nothing? Anyone?
If you are sure your battery is good, is probably some parasitic draw. One potential issue I found with my 2020 ST was that the on some occasions, the headlights would not turn off--the headlight switch would not turn it off either. I always managed to catch it before the battery completely died but replacing the headlight switch/module solved the problem. 2020 also had issues with deep sleeps and what I would assume are parasitic drains--TSB out there saying to update modules to newer firmware. It might be hard to solve, especially if this happens intermittently. I personally recommend having a voltage display in the car--my radar detector does that but some use a cig lighter plug that displays it. At least you will know if your alternator is performing correctly. Others will tell you to reset the BMS (google procedure).
EDWYER
Black 2020 ST
How many miles do you have on it?
Nascarbilly
Sacramento, CA
2025 Rapid Red Explorer ST
@Bucephalus :
Do you have an aftermarket alarm system? My 2016 GT Premium Convertible would not start if it sat for more than a week (if you drove every other day, NO problems/no indications). After being towed back to the selling dealer (3) three times, battery/alternator replacement and countless calls and emails with FORD they accidently figured out the problem. The car alarm was installed wrong and was somehow getting a electrical ground that was killing the battery.
So he tested the battery and it was good?
