Auto-close windows and sunroof?
Odin
DC area
Had this as a feature on multiple vehicles before, so I'm hoping there's some way to activate it on the Explorer. According to the manual, holding the lock or unlock button for 2 seconds is supposed to open all windows, and press/hold another 2 seconds to close all. I tried, that did not happen. Anyone know the trick to making that happen?
Thanks
Odin
KY
GLOBAL OPENING (IF EQUIPPED) You can use the remote control to open the windows with the ignition off. Note:You can enable or disable this feature in the information display, or see an authorized dealer. See General Information (page 112). Note: To operate this feature, accessory delay must not be active. Remote Control Front Windows You can open the windows for a short time after you unlock your vehicle with the remote control. After you unlock your vehicle, press and hold the remote control unlock button to open the windows. Release the button once movement starts. Press the lock or unlock button to stop movement.
Will not global close though...
