any good phone mounts that suction to the back of the vertical screen?
Toadster
Folsom, CA
'23 ExST, '17 Raptor, Factory Five Cobra
we've tried the lower mount by the cupholders, and the 3d printed one with the dragy mount, both aren't cutting it
I thought maybe a mount that suction cup mounted to the back of the vertical screen may give a new option
my wife doesn't want a vent-mount version
any success in these types of mounts?
Toadster
Toadster
Folsom, CA
Toadster
Toadster
Folsom, CA
ended up ordering their suction cup mount (which I hope will attach to the back of the screen)
and the Bulletpoint XL Dash Mount Cell Phone Holder for Oversized Phones
this paired with a 7cm CF arm should give enough clearance to the vent but not be too high either
hoping for a setup like this... gets delivered early next week
Not sure what traits you are looking for. Mine is in the same vicinity as where you want it. It's a Pro-Fit mount that i installed a ball joint to and put on a magsafe charger for my iphone. It's nice for the portrait screen because it's right next to it and i can rest my hand on top of the screen while i use the phone. NOT heavy duty though but neither is a suction or vent mount.
Grimsby, ON, Canada
I don’t have this one. But looks like it will do the job.
Kolasels Phone Holder for Tesla Model 3/Y/X/S, [Strong Suction Cup] Tesla Dashboard Phone Holder, Tesla Screen Phone Mount for iPhone 15 14 13 Pro Max Mini, Galaxy Series and All 4-7" Phones https://a.co/d/fkcSDs5
Toadster
Toadster
Folsom, CA
just FYI - the bulletpoint suction cup is WAY too big for the back of the screen, having my son 3D print a 20mm ball that I can mount with gorilla tape to see if that is strong enough for the mount :)
Dgoebel57
Faribault, MN, USA
2020 Rapid Red ST
Just saw this Carmount Minimal Mount on FB and I think they even have a ST in their advertising,
https://www.carmount.com
Dgoebel57
Faribault, MN, USA
2020 Rapid Red ST
After further research (and since I'm getting a new S24) I found the Peak Design's non-charging or charging car mount (that works with their case) that appears that it would mount on the back of the infotainment screen (but it's not suction, it's 3M double sided trim tape). The only reason I'm going with this brand, is all the testing they've done with Motorcycle Adventure Bike and off-road bike mounting retention and I need that as well. Peak designs Anti-Vibration mount held up longer than even the Quadlock in independent testing. It might be overkill if the only thing you needed was for your phone in car.
Sumner County TN
2024 Ranger Raptor
Good luck with using the tape.
Out of experience, no matter what tape. It will eventually fail. Especially if in heat. I used them all. 3m automotive, 3m heavy duty, outdoor 3m that claims it holds onto a brick wall. Even Alien tape. It all fails under weight, heat or both.
Just beware. Nothing like something fall off your window while driving and wedging under your brake pedal. Or something flying off your motorcycle.
Toadster
Toadster
Folsom, CA
Thread Starter #12
yeah, was thinking gorilla tape with a wide base of about 2" square to hold it - but maybe need to figure out how to screw mount it into the case?
TW3DC
Oklahoma
Farmers Branch, TX
Sumner County TN
2024 Ranger Raptor
