aFe CAI - Throws P040F0 Code
bigarron
Montgomery, TX, USA
Anyone have the P040F0 code after installing the aFe CAI? I have triple checked every connection and it still pops up every 150 miles after clearing on my ‘22
Roseville
I want this same CAI. hopefully you just have something wrong and someone will give you an easy fix. following to find out myself.
Calgary, AB, Canada
No issues with mine.
US
I've had mine on for months now and haven't thrown any codes.
Go back and check the install. Is every hose connected correctly and in the right spot? I haven't seen any others throwing codes with the AFE.
No codes here. Sounds like an install error.
Blue720
Wentzville
What is the part number for the crank case breather hose or connector? Or did you not have to replace yours after removal?
New York
Recently got the code myself. I didn’t have to replace the hose with the sensor on mine but I will if that can be the issue. Any lucky figuring it out on your end ?
Miami, FL, USA
2022 Explorer st
Did you guys decide to keep the turbo inlet diffusor on the passenger side or remove it.
My ST is Better!
Installed mines last weekend no codes here.
OREGON
2022 ST
No problems here with the CAI. Just loaded the "Monster Tune" and getting ready to enjoy the combination.
Jwbreeding
Active Duty U.S. Air Force
Charleston, SC, USA
Zero codes, I installed it over 5 months.
Fonsoiii
Davie, FL, USA
2020 ford explorer ST
I installed the AFE intake around a week ago ans the same code P04F0 shown up.
Conroe, Texas
Depends which evap tube you have, one is more “one time use clip” with the newer design in late 21 and 22. Earlier models the clip system isn’t so prone to not going back on.
play with the connector, if it won’t clip and seal just order a new one from Ford. I have no freaking clue why Ford would make this change in the part, but they did.
