2025 ST Lowered using Eibach springs, driver side rear shock leaking.
Combatvet
This is just a heads up, never tracked, under 8000 miles, and the factory strut is already leaking. Already picked up an OEM replacement as no upgraded version is available per Steeda. You can buy a new strut for about $130.00 if you use anyone other than a dealer, as the stealership cost is $240.00.
It’s actually a common thing for the struts/shocks to leak even at stock height. Not cause of your Eibachs most likely.
PIU is the way to go.
