2025 Ford Explorer ST Resetting the Oil Life
Birmingham, AL
These are the instructions from the owner's manual, but I do not have vehicle maintenance option on my google infotainment. I only have vehicle status which gives me the oil life, but does not allow me to reset the oil life.
Engine Oil - Resetting the Intelligent Oil Life Monitor
  1. Press Settings on the touchscreen.
  1. Select Vehicle Maintenance.
  1. Select Oil Life.
  1. Press and hold the OK button until the system reset confirmation appears.
California
See if you can do it the way they do it on the earlier ones's on the steering wheel press menu then go to settings and then oil life and see if you can reset it from there. (watched a YouTube Video on it) I had the dealer do mine so I have not even checked yet to see if the vehicle maintenance page is in the infotainment center, but since you say its not then I guess either they made a typo in the manual or they need to do an update to add that page in. lol
New Jersey
Thanks for this. I kept assuming it would be on the right touchscreen, and didn't even think of using the steering wheel menu. I could not get it to work from the oil alert menu on the infotainment.
