2022 Explorer ST Build
Automovil
Chicago
Thread Starter #21
Just extend the slots for the oem camber adjustment…takes just a few minutes with a carbide bit on a right angle die grinder.
That's what I will end up doing when i get around to it. Have to have plates welded to my front struts to fix camber up there.
Depending on how much camber you need to dial out you can elongate the top holes on the strut too. Welding the slotted tabs on is definitely an option but slotting the holes is fast and free.
New Jersey
2021 explorer st
You have a picture of the wheel? I'm thinking of getting a new steering wheel.
Automovil
Chicago
Thread Starter #24
Yes, Here is mine !
The guy makes then in different colors Regular / Forged Carbon / Heated & Non Heated
Yes, Here is mine !
Is that from Cody Ball?
Automovil
Chicago
Thread Starter #28
Next week starting paint match all the way around and SS Tuning wide body.
Automovil
Chicago
Thread Starter #29
Just placed an order will be adding SS Tuning front lip and rear top spoiler to go with the wide body
Phoenix, AZ USA
'25 Expl. ST, Rapid Red
#30
Welcome to my build !
2022 Explorer St
Suspension
- FV Suspension Air Ride With Air Lift Management
- Steeda Front & Rear Adjustable Sway Bars
- Steeda Rear Adjustable Toe Links
- Speedlogix Rear Vert Links
- Fenfab Driffty Stiffy Brace
https://www.tiktok.com/@tuners
Please check me out on social media
Instagram - @Automovil
Tik - Tok - @Tuners
PLEASE tell me about this FV Suspension Air Ride With Air Lift Management. I searched for that and found Air Lift Performance, but they had no kits listed for the Explorer.. Maybe U have a link U could share? I'd LOVE to have adjustable ride height on my 2025 ST.
Automovil
Chicago
Thread Starter #31
I couldn’t find it now that I was looking. Don’t know if they stopped making them or changed name or what. But check out graveyard performance they make a lot for the explorer as well.
Automovil
Chicago
Thread Starter #32
Car is at the body shop... Getting Paint matched and SS Tuning fender flares & rear hitch cover. Also just put an order in for the SS Tuning front lip and rear upper spoiler
Phoenix, AZ USA
#33
TYVM.. Have checked out the kit and will have Graveyard install it; I'll be doing it probably early next year.. I'm in Phoenix, Graveyard is in n. SaltLakeCity, so I'll drive up, leave the car, stay overnight, and drive home.
FYI…Graveyard and FV coil over kits are the exact same parts. They’re white labeling them from somewhere in Asia.
#35
If you’re doing coillovers, BC Forged is the only good option. Graveyard/FV coilovers are cheaply built.
Automovil
Chicago
Thread Starter #36
I know they are. I run FV Air.
