2020 ST P0524 code Low oil pressure
new jersey
2020 explorer st
My ST only has 20k miles and I just got the P0524 code. Low oil pressure. Thankful that I bought the cheap extended warranty as my 3 year warranty is up by 3 months.
Does anyone know where the oil pressure sensor is on this engine is located?
Or perhaps it's worth taking to the dealer to have them fix it and have it documented.
This was shortly after replacing the evap purge valve last month. Which was not fun due to the location.
deadhead20st
new jersey
2020 explorer st
Answering my own question. Oil pressure sensor is under the oil filter housing. Have to take the air cleaner off. Then it can be taken off with a 24mm wrench.
